Creating surfaces for Boolean Subtraction
Old   July 25, 2020, 11:50
Default Creating surfaces for Boolean Subtraction
mindthegap_ar
mindthegap95@icloud.com is on a distinguished road
Hello all,
I'm modelling a 3D wing and wasn't getting a great mesh at my trailing edge it was more rectangular than it was curved, so I went back into my CAD and created the trailing edge as a separate body that I could add a custom surface control to. Now my issue is I cannot keep the trailing edge body separate from the rest of the wing when I perform a Boolean subtraction, no matter how many times I try rename surfaces differently before the Boolean operation StarCCM+ always goes against my wishes and combines surfaces with others. Maybe it's something simple that I'm missing but any help would be appreciated, I've attached some screenshots of how I would like to keep the wing as two bodies; wing (without TE) and the TE, the third screenshot is of the result StarCCM+ gives me.
Thanks
mindthegap95@icloud.com is offline   Reply With Quote
Old   July 26, 2020, 14:40
cwl
Chaotic Water
cwl is on a distinguished road
Originally Posted by mindthegap95@icloud.com View Post
Hello all,
Thanks
Would be easier just to split surface by imprinting a sketch for example.
Sounds confusing. Can you upload the simulation if that is possible? - Would make it much easier to deal with the problem.
cwl is offline   Reply With Quote
Old   July 26, 2020, 15:06
mindthegap_ar
Thank you for your response Chaotic Water,
What do you mean by split surface through imprinting a sketch?
Sure I can upload the simulation, I have named two bodies 'aerofoil front" and "trailing edge" the rest are the vortex generators.. what I am trying to achieve is for the "aerofoil front" and "trailing edge" bodies to not merge faces with one another after a boolean subtraction operation. The reason being is so I can add separate control surfaces to each in other to make the meshing process easier.
Thanks
mesh, part contacts, starccm+, subtract, surface
From surfaces to bodies Prothean STAR-CCM+ 5 January 13, 2020 10:34
[ANSYS Meshing] ANSYS 2D Geometry/Meshing Plugin Error: Attach Failed, No Valid Bodies Found cdase ANSYS Meshing & Geometry 0 August 26, 2018 14:31
[DesignModeler] Find face normals to selected faces Pallati ANSYS Meshing & Geometry 1 July 26, 2017 11:04
[ICEM CFD] Problem meshing two indipendent but contacting bodies Faggio11 Main CFD Forum 0 December 12, 2016 09:31
[Other] how to define complex/irregular bodies in the mesher Ema40 OpenFOAM Meshing & Mesh Conversion 4 March 9, 2016 16:04
