EHP plugin with Star-CCM+ only detects hull geometry error after clicking setup |
July 29, 2020, 13:37 |
I am currently working on my thesis which involves the use of EHP plugin on Star-CCM+ and I am a beginner with using Star-CCM+. The geometry I used is from Maxsurf Academic Samples which I have applied Parametric Transformation on. When I import it on the EHP plugin and check the hull geometry, it says that it does not detect any errors. However, after I click setup the following errors pop up (files attached). I am not sure why this is the case. This is not the geometry ideally wouldn't want to use but because the KCS geometry I have obtained from the Simman website I was hoping I can apply parametric transformation on this geometry and that will have similar dimensions as the KCS hull. Can anyone please help me? |
July 31, 2020, 02:28 |
Ping
Rep Power: 20 |
i suggest you first import the surfaces into 3D-CAD or Parts and repair the problems highlighted to get a closed surface with no errors then export and try ehp again
ehp, geometry issues, star-ccm |
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 22:15 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
