Mesh refinement field function
Old   April 17, 2020, 10:11
Default Mesh refinement field function
Alessandro Donadeo
AlphaDelta is on a distinguished road
Hello.
I would like to create, if possible, a mesh refinement field function.
I would like to refine the mesh around some curves. (belonging to the geometric parts)
The result should be a sort of tubular structure, where each point of the curve has a portion of spherical space with refined mesh around it.
What expression can I use to define the function?
AlphaDelta is offline   Reply With Quote
Old   September 7, 2020, 10:28
Default Table-based Mesh refinement
Bill
kasujin12 is on a distinguished road
Hi Alessandro,
https://apps.dtic.mil/dtic/tr/fulltext/u2/1069198.pdf
Here you can find an idea about how to proceed with your question.
Greetings...
kasujin12 is offline   Reply With Quote
curve, field function, mesh, refinement
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] Not Able to Refine Mesh in Refinement Box noodleluvmay OpenFOAM Meshing & Mesh Conversion 2 January 27, 2020 10:55
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
