December 11, 2020, 07:01 |
Bad cells cause divergence
Rep Power: 5 |
I am trying to simulate the wind flow around two buildings represented by simple blocks. I am using trimmed mesh and my problem is that I get 3.3% of bad cells (i have activated cell quality remediation) and my solution diverges after around 100 iterations. My goal is to get the velocity between the buildings which is why the most refined is there. I am using Thresholds to visualise where the bad cells are. I have some cells with a skewness angle higher than 85 on the edges of the buildings and the whole ground has a volume change of less than 0.01. These are the values that define the bad cells according to the documentation. There aren't any cells with cell quality less than 1e-5. I would like to know how i can improve my mesh quality since it seems to be the reason for the divergence. I am attaching images of my mesh. I am using a symmetry plane between the buildings which is why only one building is visible. |
December 11, 2020, 12:30 |
Blegh
Rep Power: 5 |
can you give us some insights about the physical values? what kind of simulation you are doing: steady, unsteady, turbulence modell etc
December 11, 2020, 13:25 |
Rep Power: 5 |
It's a steady state simulation and I am actually testing different turbulence models - Spalart-Allmaras, k-w SST and Reynolds Stress Model. In this particular case I was using SA and it diverged and I guess it is due to the mesh quality.
December 17, 2020, 09:23 |
Blegh
Rep Power: 5 |
Which model are you currently using and what is your Y+ value? How many prism layers do you use?
December 17, 2020, 14:28 |
Rep Power: 5 |
I am using 12 prism layers and y+ value is less than 1 at most places. I am currently focused on using Spalart-allmaras.
bad elements, divergence, mesh, mesh quality |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
[ICEM] Error in mesh writing | helios | ANSYS Meshing & Geometry | 21 | August 19, 2021 14:18 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Floating point error and divergence detected | aannjj | FLUENT | 0 | July 2, 2013 03:44 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
