December 31, 2020, 13:09 |
Parabolic inlet velocity help
jas
Rep Power: 5 |
I need help. In the first picture I have correctly implemented a parabolic inlet velocity profile for a pipe. Everything is the same for the second picture however the inlet profile is different. Can someone help me on this please thanks.
Screenshot 2020-12-31 at 18.06.38.pngScreenshot 2020-12-31 at 18.07.20.png |
January 1, 2021, 11:58 |
#2 | |
Lefteris
Rep Power: 15 |
Your coordinate systems are different.
Lefteris |
January 2, 2021, 10:17 |
jas
Rep Power: 5 |
January 2, 2021, 15:11 |
#4 | |
Lefteris
Rep Power: 15 |
To begin with, this doesn't give much information on what you've done. Which one is the inlet, which is the outlet? Then, you've used a cartesian coordinate system but based on what you've asked in other threads, you seem to have implemented a function that needs a cylindrical coordinate system. Then, even if you have defined successfully the parabolic profile for one inlet, you need to repeat this if you have multiple inlets that each one has a local (cylindrical) coordinate system. Take the time to analyse your problem and think and understand what you're doing and what you need to adapt.
Lefteris |
January 2, 2021, 16:49 |
#5 | |
jas
Rep Power: 5 |
January 4, 2021, 05:56 |
Lefteris
Rep Power: 15 |
Plot the velocity contours and vectors on the inlet face and see what happens.
Lefteris |
udf parabolic velocity inlet with unsteady case | Faruk Beyca | FLUENT | 4 | June 24, 2022 10:45 |
Parabolic inlet velocity profile | msrinath80 | OpenFOAM Running, Solving & CFD | 157 | February 6, 2020 05:13 |
codeDict Error Parabolic Power Law Inlet Velocity Profile | Sindibad | OpenFOAM Running, Solving & CFD | 0 | January 1, 2017 19:53 |
How to define a parabolic velocity inlet of particles with UDF | zumaqiong | FLUENT | 2 | February 22, 2010 09:46 |
Exponential or parabolic velocity in inlet | Kim, Hongju | CFX | 1 | December 18, 2000 17:12 |
