January 4, 2021, 16:34 |
Calculation Hidrodynamic & Aerodynamic Lift
ali_Ebrahimi
Rep Power: 5 |
Hi
I work in the field simulation CFD high speed planing in STAR CCM+. I want to calculate Hydrodynamic & Aerodynamic Liftseparately in multiphase flow (water & Air). Do you suggest a way to do this? |
January 7, 2021, 05:46 |
Ping
Rep Power: 20 |
this is easy using a new threshold with the part surface you require forces measured on as the input part, the scalar field function set to the volume fraction of water or air, and the range 0,.5 or .5,1 depending on which field is chosen. this creates a new derived part which is a subset of the chosen input part and you do your force calcs on this new part
January 8, 2021, 03:03 |
#3 | |
ali_Ebrahimi
Rep Power: 5 |
However, the sum of the aerodynamic and hydrodynamic lift forces calculated from the threshold will not be equal to the total lift force calculated from the part region. I share photos of the settings made. Last edited by ali_ebrahimi; January 8, 2021 at 09:51. |
January 8, 2021, 04:50 |
Ping
Rep Power: 20 |
check the threshold parts in a geometry scene to make sure your threshold subsets of those surfaces are correct since it looks to me like you have used .05 instead of 0.5
cfd analysis, high speed planing, lift force, star ccm+ |
How to calculate lift, drag and lift distribution in Star CCM+? | israelcasillas94 | STAR-CCM+ | 4 | November 6, 2020 08:35 |
calculation of Lift problem | imran99 | FLUENT | 0 | April 9, 2015 06:37 |
Aerodynamic Force, analytical calculation | punnag | Main CFD Forum | 0 | December 31, 2014 16:45 |
Calculation of Lift | nauman55 | FLUENT | 1 | July 12, 2012 06:54 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
