Morphing + superimposed motion
Like Tree2Likes
  • 2 Post By SimulatorMaster
Old   June 14, 2021, 05:38
Default Morphing + superimposed motion
Pietro
pi120 is on a distinguished road
I am modeling a floating wind turbine which has to translate back and forth (superimposed translation) but its blades also deform via fluid-structure interaction (morphing motion). As far as I know I can set up a superimposed translation or a morpher to a single region in star-ccm+.
Is it possible to apply a superimposed motion as well as a morphing motion to the same region in star-ccm?
Pietro
pi120 is offline   Reply With Quote
Old   June 14, 2021, 07:00
SimulatorMaster's Avatar
Onur
SimulatorMaster is on a distinguished road
Hello Pietro
It is possible. You should take a look at the avaliable tutorial under Solid Stress tutorial file in Help.
Tutorial name: FSI with Prescribed Solid Motion: Flapping Wing.
-The overset wall should be set to morphing with floating type so the overset region will compensate for the displacement of the object.
-You can then impose your desired motion.
I highly recommend you to take a look at the tutorial. It does an exceptional job explaining the details.
Take care
TommyM and pi120 like this.
SimulatorMaster is offline   Reply With Quote
morphing, motion dynamicmesh, overset mesh, superimposed velocity
dynamicFvMesh - tabulated motion of a solid body + mesh morphing HendrikW OpenFOAM Pre-Processing 3 December 3, 2019 02:05
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 04:27
DFBI Morphing for roll and heave motion Lingfeng Su STAR-CCM+ 0 November 10, 2015 07:08
External management of solid motion (using dynamicmesh) maxou1993 Main CFD Forum 0 July 28, 2015 11:37
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
