Applying Momentum source to a cell adjacent to supply diffuser
Old   September 23, 2021, 10:51
Question Applying Momentum source to a cell adjacent to supply diffuser
Elsarraj_11 is on a distinguished road
I have been trying to implement the momentum method to model a supply diffuser. In this method, we consider the actual area of the diffuser and decouple the mass and momentum boundary conditions. However, this is not possible using star ccm+ or any commerical CFD packages. As a result, The inlet mass flow rate is given at the grille diffuser surface, and the momentum flow flux provided by the diffuser is specified as a momentum source added to a volume (the first gird layer) adjacent to the diffuser.
I am not sure how to add a momentum source to a cell, I was wondering If any of you do and If you could please explain this to me. I would greatly appreciate your expertise.
Elsarraj_11 is offline   Reply With Quote
diffuser, momentum source, star-ccm+, ventilation
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 03:50
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
