October 16, 2021, 07:43 |
2D overset mesh not interacting
Yi Xiang Guice
Rep Power: 4 |
Hi everyone, I have a problem regarding overset mesh. This is my first attempt at using the tool motion and also trying to do overset mesh. I am not sure why the region containing the savonius wind turbine does not blend in together with the rest of the body.
The process of me creating this model is as below: a vertical axis wind turbine model a cylinder covering the wind turbine a block subtract wind turbine from the cylinder [1] subtract the cylinder from the block [2] assign [1] and [2] to region This image is the pressure scalar scene. https://imgur.com/a/iIUcWoP Any help will be appreciated. Thanks in advance. |
October 16, 2021, 19:17 |
#2 | |
Peresvet
Rep Power: 5 |
overset mesh, rotate body |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Is overset mesh required? | ahildershavn@yahoo.no | OpenFOAM Running, Solving & CFD | 2 | August 4, 2017 03:23 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
