December 6, 2021, 15:46 |
Directed Mesh
Bal
Rep Power: 4 |
Hi Again,
I know that I'm asking a very simple question, but I'm stuck trying to figure what I'm missing for 10 hours. Simple, I'm trying to generate a directed mesh. The source & target surfaces are rectangular. So I know that eventually I need to define the "patch topology" to be able to activate the "batch mesh", etc. But I'm unable to activate the patch mesh. Can you have a look at the picture of the source surface? Any hint is really appropriate. |
December 6, 2021, 15:50 |
Bal
Rep Power: 4 |
December 7, 2021, 06:49 |
Rep Power: 11 |
Hi. You should create a patch mesh under source meshes. Then you can use auto populate to create initial points at vertexes. Lastly, you can select any line and with the split tool you can devide the line to desired number of points. I have tried to add an image. I hope I could |
December 7, 2021, 07:11 |
Bal
Rep Power: 4 |
Thanks a lot. I will give it another try and revert.
December 7, 2021, 08:15 |
Still not working unfortunately
Bal
Rep Power: 4 |
It worked. Thank you so much.
directed mesh |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] High quality mesh for wind in complex urban environment | ziboaa | OpenFOAM Meshing & Mesh Conversion | 1 | January 12, 2021 15:33 |
GeometricField -> mesh() Function | Tobi | OpenFOAM Programming & Development | 10 | November 19, 2020 11:33 |
Directed Mesh | badger1 | STAR-CCM+ | 7 | March 1, 2013 13:29 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
