December 14, 2021, 00:12 |
Cd does not converge to published value
Rep Power: 4 |
I am flowing a (1m) NACA 2412 airfoil to which the Cl has converged on correct published values. Yet, the drag coefficient is not, and maintains a 5.75x -> 6.00x difference through different alpha profiles. What am I doing wrong here? Thanks in advance.
December 14, 2021, 06:46 |
#2 | |
Chaotic Water
Rep Power: 17 |
In general drag is mostly viscous - so you might not be resolving well enough the boundary layer, including transition. |
cd drag coefficient |
Need help running CONVERGE for the first time | ad1314 | CONVERGE | 2 | May 25, 2021 15:40 |
Are simulations done in Converge 3.0 not possible to do in Converge 2.4? | EternalSeekerX | CONVERGE | 1 | March 29, 2021 07:10 |
Installed Converge on CentOS 7, converge solvers via command line work, gui doesn't? | EternalSeekerX | CONVERGE | 1 | December 2, 2020 10:15 |
tutorial guide of converge | Weiqiang Liu | CONVERGE | 4 | August 6, 2020 04:24 |
HELP !In relaxtion factor converge is taken or not | MANOJ KUMAR | FLUENT | 5 | September 22, 2005 04:16 |
