when increase compute process solution time does not change
Old   January 7, 2022, 11:35
Default when increase compute process solution time does not change
Halit Guvenc
hguvenc is on a distinguished road
Hello everyone,
I want to ask that; I have 10 core 20 thread cpu, I started star ccm in paralell on local host and entering 10 process to 18 process. cpu usage changes %50 to %100 but iteration time goes 8.3sec to 8.0sec nearly. There is really a little bit difference. What am I doing wrong? Anyone has answer for that.
when I started 2 simulation same time iteration time changes 15sec.
thanks,
hguvenc is offline   Reply With Quote
Old   January 7, 2022, 11:46
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
Because multi-threading doesn't actually do anything. Even intel has given up it.
After 10, all your new threads are being run on virtual cores. You should be happy seeing any benefit at all.
LuckyTran is offline   Reply With Quote
Old   January 7, 2022, 11:54
Halit Guvenc
Its too annoying to see that cpu working 50% and 100% but solves in the same time.
Old   January 7, 2022, 11:57
Lucky
Just turn off multi-threading
Old   January 7, 2022, 11:58
Halit Guvenc
Do you know has mpi selection effects solution time and which one is better?
Old   January 7, 2022, 12:04
Lucky
They do but there is no general answer to that. You have to do detailed benchmarks. And it is probably one of the last things you should worry about on a single node machine.
Old   January 7, 2022, 12:06
Halit Guvenc
I look at the internet and user guide to turning off multi-threading. Can you give a little bit info about that?
Sorry if I askıng a lot
Old   January 7, 2022, 13:09
Lucky
It is a BIOS setting. Restart your computer (turn it off and on). And then you have to press a certain button within the first few seconds when it turns on before your OS loads. It could be any of the F# keys or del. F10 and F12 are very popular. If you see the Windows logo then you are too late.
Without knowing exactly what motherboard you have, I can't tell you what key you have to press or what the BIOS menu even looks like. It varies widely from one OEM to the next and varies even within an OEM.
Old   January 8, 2022, 02:38
Halit Guvenc
Thank you for your help
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 09:10
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
