when increase compute process solution time does not change |
January 7, 2022, 11:35 |
Halit Guvenc
Rep Power: 4 |
Hello everyone,
I want to ask that; I have 10 core 20 thread cpu, I started star ccm in paralell on local host and entering 10 process to 18 process. cpu usage changes %50 to %100 but iteration time goes 8.3sec to 8.0sec nearly. There is really a little bit difference. What am I doing wrong? Anyone has answer for that. when I started 2 simulation same time iteration time changes 15sec. thanks, |
January 7, 2022, 11:46 |
Lucky
Rep Power: 66 |
Because multi-threading doesn't actually do anything. Even intel has given up it.
After 10, all your new threads are being run on virtual cores. You should be happy seeing any benefit at all. |
January 7, 2022, 11:54 |
#3 | |
Halit Guvenc
Rep Power: 4 |
January 7, 2022, 11:57 |
Lucky
Rep Power: 66 |
Just turn off multi-threading
January 7, 2022, 12:06 |
Halit Guvenc
Rep Power: 4 |
I look at the internet and user guide to turning off multi-threading. Can you give a little bit info about that?
Sorry if I askıng a lot |
January 7, 2022, 13:09 |
Lucky
Rep Power: 66 |
It is a BIOS setting. Restart your computer (turn it off and on). And then you have to press a certain button within the first few seconds when it turns on before your OS loads. It could be any of the F# keys or del. F10 and F12 are very popular. If you see the Windows logo then you are too late.
Without knowing exactly what motherboard you have, I can't tell you what key you have to press or what the BIOS menu even looks like. It varies widely from one OEM to the next and varies even within an OEM. |
January 8, 2022, 02:38 |
Halit Guvenc
Rep Power: 4 |
Thank you for your help
January 7, 2022, 11:58 |
Halit Guvenc
Rep Power: 4 |
Do you know has mpi selection effects solution time and which one is better?
January 7, 2022, 12:04 |
Lucky
Rep Power: 66 |
They do but there is no general answer to that. You have to do detailed benchmarks. And it is probably one of the last things you should worry about on a single node machine.
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
