May 15, 2023, 13:23 |
Modeling Combustion
Goal: model deflagration and/or detonation wave of gaseous fuel in non-premixed duct using Eddy Break-Up Model.
Background: I have 3 years of experience with modeling internal and external airflow in Star-CCM+ and have ventured into modeling combustion. I have completed some of the Star tutorials for combustion, but something isn't carrying over into this project and it is not immediately obvious. First off, I have a geometry and I believe my mesh is sufficient. This is a 3D analysis. I have set up my boundary conditions (regions). I am using Eddy Break-Up model in my physics. I have defined my reactions the best I could with products and reactants. My fuel is propane. The setup: I have an inlet and an outlet to move the air. I am using an injector to bring in parcels of fuel, defined as a mass flow rate. I have the injector in a corner, far enough to not be negatively affected by the inlet. I then put a region of high temperature (a cylinder) to start the combustion as the parcels pass through it. I am doing this because I also failed at using the ignitors feature. Time step in 1.0e-4. When I run the simulation, it crashes at 20 steps. What I would like to know: - Is the Eddy Break-Up model the correct model for this and am I employing it's use correctly? Is there something I am leaving out? - Is my approach correct for thinking a hot spot could ignite my reactants and fuel? Should I just try to make the ignitors work? - Do I need my initial conditions to include products for intermediary reactions to support combustion? If any more information is needed, let me know. I appreciate any and all help. Thank you. Last edited by StarCCM4Life; May 16, 2023 at 14:20. Reason: Adding information. |
combustion, deflagration, detonation, star ccm+ |
Problem with Finite Rate in Combustion Modeling | mengke | FLUENT | 1 | March 8, 2021 14:09 |
Spray combustion modeling in ansys fluent | anu4anusai | ANSYS | 0 | November 30, 2019 23:49 |
Where to start using CFD combustion modeling? | urbansound | Main CFD Forum | 2 | November 2, 2018 08:13 |
dual fuel combustion modeling in starcd | hkoten | STAR-CD | 0 | May 13, 2012 09:12 |
combustion modeling | sara | FLUENT | 4 | September 5, 2005 06:37 |
