Porous media knowing flowrate
Old   July 3, 2023, 12:15
Default Porous media knowing flowrate
m b
bmax2 is on a distinguished road
Hi everyone I'm trying to model a conic filter in starccm+.
The infos i have about this filter are: porosity, flowrate, surface area and pressure drop through the filter.
I'm modeling it using the porous baffle media (shear stress based). How can i set the pressure drop to be exactly the one specified in the data sheet i have been given? I tried following the ansa help guide and Ergun equations but when i run the simulation with the numbers i found for Pi (porous inertial resistance) and for Pv (porous viscosity resistance), it gives me meaningless results.
Thanks in advance for any reply
bmax2 is offline   Reply With Quote
Old   July 3, 2023, 15:18
Maddin is on a distinguished road
Did you check the help? "Examples of Setting Porous Resistance Properties"
Maddin is offline   Reply With Quote
Old   July 4, 2023, 05:14
cwl
Chaotic Water
cwl is on a distinguished road
From what I remember - there is a "ρ·" part in pressure drop formulation for the porous baffle resistance. Did you check that? - Why would you use ANSA help guide while setting up the simulation in STAR-CCM+?
... it gives me meaningless results.
I'm afraid that without any details the question is also meaningless - like "My car won't start".
cwl is offline   Reply With Quote
Old   July 4, 2023, 09:03
m b
because i was using ansa while posting this i'm sorry i got confused lol, i used starccm+ guide ofc. The meaningless results are that starccm+ with my Pi and Pv, is seeing the filter like a wall, i can note it from the velocity and pressure plots. I did check all the starccm+ help manual and this forum too so my question now would probably be: are the infos i have about the filter enough to model it or do i have to check for more? Now i used all the infos i found on the data sheet of the filter
Old   July 4, 2023, 09:04
m b
yes i checked everything on the help also on this forum too, and on some other people's work with filters
Thermal non-equilibrium porous media model with conjugate heat transfer Hexahedron FLUENT 9 February 22, 2023 02:55
Porous Media Zone Thickness TheKitchenCleaner FLUENT 0 October 5, 2020 00:42
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
