October 13, 2023, 03:58 |
Natural convection is not converging
Bohn
Hi all,
for my master thesis i need to simulate a heatingsystem for a church. Therefore i simplified the construction to a big room with one block of heat source in the middle. There is a small heat flux loose through the walls an i already added the model S2S-Radiation (gray thermal radiation). The velocity vectors make sense to me, but the block doesnt heat up the surrounding space. I am using the version STAR-CCM+ 2022.1 Build 17.02.007. The phsyics models are: All y+ wall treatment gas gradients gravity gray thermal radiation ideal gas K-Omega Turbulence Radiation (S2S) RANS Segregated Flow Segregated Fluid temperature Solution interpolation SST (Menter) K-Omega Steady 3D Turbulent View factors calculator Wall distance Any ideas what i could do? Thank you in advance! |
October 31, 2023, 00:45 |
songning yu
what are the boundary conditions? maybe the flow is because of the boundary conditions?
PS:I was once faced with a similar problem, as the coolant can't bring away the heat of batteries, then I used impress/weak contact to create interface between them and the problem is solved. |
heat source, heating system, natural convection, radiation convection |
Flow is not converging in natural convection problem of boussinesq model for air | rahulsharma | FLUENT | 4 | December 2, 2020 21:07 |
Transient natural convection, and immediately forced convection | intied | FLUENT | 2 | February 7, 2019 18:38 |
Natural convection not converging | ThatGuy | STAR-CCM+ | 0 | May 2, 2016 05:20 |
Thermophysical properties for natural convection | Ciefdi | OpenFOAM Running, Solving & CFD | 0 | November 7, 2013 11:44 |
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 09:26 |
