How to measure the position of the free surface?
Like Tree5Likes
  • 4 Post By ping
  • 1 Post By Hernán
Old   November 16, 2009, 09:28
Default How to measure the position of the free surface?
Hernán
Hernán is on a distinguished road
Hello, good afternoon.
We are simulating several laboratory tests with Star CCM+ (tests carried out in a wave tank), in order to compare the results of the physical model with numerical model, we must to take measurements of free surface position (free surface elevation in z axis) along different points.
How is the manner to record this data (a probe, a point), creating another derived part?
I hope this information is enough, if you need more details, please contact me.
Thank´s for your attention.
Best regards.
Hernán is offline   Reply With Quote
Old   November 24, 2009, 15:25
Aroon
vishyaroon is on a distinguished road
You can create a Point Probe or a Plane Probe as is necessary and generate a report to check your results
vishyaroon is offline   Reply With Quote
Old   November 25, 2009, 00:24
Ping
ping is on a distinguished road
NB: a point or line probe is not the answer in this case. Here is what to do:
1. Create an iso-surface at VOF=0.5
2. Create a vertical plane section at the x location but with the iso-surface as the input part. The resulting section is then a line at the intersection of the isos and the plane
3. Create another vertical plane section at the required y location and use the above line section as the part.
Now that section is actually a point at the intersection of those three parts - since one of them is the water height it will move up and down during solution.
4. Create a Max report with field function Position[2] - ie z and the point section as the part.
5. Create a monitor and plot of this report - DONE.
ftb, Loux27, SiemenDiemon and 1 others like this.
ping is offline   Reply With Quote
Old   November 25, 2009, 03:44
Hernán
Hello, good morning from Spain,
Thank´s for your prompt reply.
We have found another proccedure for measuring the position of free surface, is the following method:
1.- Create a vertical plane section normal to wave advancing direction.
2.- Create a report to measure the Area Averaged at this section.
3.- Set at this report Volume Fraction of Water as Scalar field function.
4.- Create a monitor and a plot from this report.
5.- The values you will obtain are the percentage of water you have at this section, in another words, the water level time series at this point.
Best regards.
Loux27 likes this.
Old   November 26, 2009, 02:36
Ping
Yes this is also a good method which I use when I require the hgt averaged across a plane (and if you want it in just say a 1m wide plane then define a constrained plane).
However you requested the level at 'points' rather than planes so this is the method I suggested - eg to track the bow wave development from a boat hull - very three dimensional.
Old   March 17, 2010, 22:04
dave
davedave121 is on a distinguished road
how can i create a surface elevation plot for the free surface?
davedave121 is offline   Reply With Quote
Old   August 17, 2021, 00:16
Default Wave Height Determination in FLUENT
Frimpong Opoku
gafopoku is on a distinguished road
Hi all!
I generated a wave in a numerical wave tank, but now I want to plot time history of wave elevation at a specified position to be able to determine the wave height. I read on the CFX forum that the CEL to use on a Plane is:
areaInt(Water.Volume Fraction)@Area Region/area()@Area Region
This doesn't seems to work with Fluent. Can anyone help me with how to navigate this problem? Thank you.
gafopoku is offline   Reply With Quote
free surface elevation, physical model, wave tank
Free Surface Position Jennifer CFX 3 November 17, 2008 01:51
CFX 4.4 New free surface option Viatcheslav Anissimov CFX 0 April 3, 2002 06:27
gravitational force for free surface flow Jongtae Kim Main CFD Forum 1 July 2, 2000 11:57
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
