June 10, 2010, 20:31 |
Mesh with repeated volumes
Matt Lynam
Rep Power: 15 |
I am meshing a unit cell of a system in order to reduce the complexity of the overall system. Being a unit cell, it has certain repeated structures in the geometry. The issue I am having is that when I create the mesh in STAR-CCM+ (the geometry is modeled in solidworks) it will create one instance of each structure thereby leaving out any copies. Is this behavior normal? and will it affect my results? Thanks in advance.
ML |
June 14, 2010, 13:31 |
Matt Lynam
Rep Power: 15 |
by the way if anyone else had this issue the problem has been solved. changed from "largest internal" volume specification per region to "seed point" then placed seed points in the respective volumes.
June 15, 2010, 08:03 |
Robert
Rep Power: 16 |
Why don't you use the surface remesher on the parasolid instead of the surface wrapper?
From my experience SolidWorks gives surfaces and CCM+ handles them well. |
July 6, 2010, 12:24 |
Rep Power: 21 |
After using the surface wrapper, i would use the surface remesher anyway....
Mlynam, i'm not sure if i understand it the right way, but check the in-place interfaces if they can help you. Best regards |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
"Unit" the mesh of two volumes | meshinggod | ANSYS Meshing & Geometry | 6 | November 10, 2009 05:43 |
mesh of more than one volumes in icem cfd | ravi | CFX | 0 | February 4, 2006 10:24 |
