Ahmed Body on 25degree
Like Tree1Likes
  • 1 Post By dimsum
Old   March 16, 2011, 16:16
Default Ahmed Body on 25degree
dimsum is on a distinguished road
Hello everyone,
I am an undergraduate who is doing a ahmed body with 25degree. This is the first time that I use a CFD software.
I have a question about the residual plot when you start running the report.
The Tdr line starts going up and down when iteration start from about 150+. May I ask is there any problem to do with the model or mesh?
Here is my setting:
inlet velocity: 40m/s
turbulence intensity: 0.5%
surface mesh: polyhedral mesher, prism layer mesher and surface remesher
physics: constant density, gas, k-epsilon turbulence, realizable k-epsilon two layer, reyonlds-average navier stokes, segregated flow, steady, three dimensional, turbulent and two layer all y+ treatment.
where the base size of the mesh is 100mm and mesh in the body is min: 1mm and target: 5mm. The floor and the wall is in slip condition. There are 4 prism layers around the body which is 1mm thick, growth rate: 1.2
Please help me out. Thanks
mina likes this.
dimsum is offline   Reply With Quote
Old   March 17, 2011, 15:28
Vinicius Girardi
Vinicius is on a distinguished road
In which order of magnitude it is oscilating?
Vinicius is offline   Reply With Quote
Old   March 22, 2011, 08:16
abdul099 is on a distinguished road
I expect the flow to seperate from the body, producing some vortices behind the body. That may be a reason for the osscillation, as you are running this case in steady state.
What are the other residuals looking like? And the forces on the body?
Cheers
abdul099 is offline   Reply With Quote
Old   August 18, 2011, 06:35
Girish Gaikwad
girishg is on a distinguished road
try using trimmer mesh...
girishg is offline   Reply With Quote
[GAMBIT] Ahmed Body 3D mesh Saima ANSYS Meshing & Geometry 19 February 10, 2018 11:59
Ahmed Body andrea.pasquali OpenFOAM 10 June 18, 2016 03:16
Drag over Ahmed body Shamoon Jamshed FLUENT 2 May 18, 2009 14:15
Can't get good results on ahmed body research Michael Main CFD Forum 8 September 17, 2008 13:55
aerodynamic of Ahmed body VORTEX FLUENT 1 August 7, 2006 20:48
