Capturing Multiples scènes in a time step fails
Old   July 5, 2011, 10:35
Default Capturing Multiples scènes in a time step fails
djan
jetboo is on a distinguished road
Hi, here is my problem, i want to capture 3 differents scene in a time step, the first one is captured correctly but, in the two others the grid is translated for an unknown reason.
(See the attached pictures)
The pressure scene : (which is fine because its the first selected to be captured)
https://docs.google.com/leaf?id=0B5t...lZWE1&hl=en_US
The turbulent kinectic energy where the grid is translated
https://docs.google.com/leaf?id=0B5t...jNDBm&hl=en_US
The Volume Franction where the grid is also translated
https://docs.google.com/leaf?id=0B5t...yMjNm&hl=en_US
Do you have any idea ?? it seems to me this is a bug...
jetboo is offline   Reply With Quote
Old   July 10, 2011, 05:35
abdul099 is on a distinguished road
My first thought would be, the plane section are not identical. There is no reason why ccm+ should calculate a different section for the same mesh at the same position just due to a different scalar to display (which is pretty much just a colored overlay).
When you create one plane section and create three scenes containing this single plane section, the mesh has to be displayed identically.
abdul099 is offline   Reply With Quote
Old   July 10, 2011, 09:57
djan
Well it's a 2D simulation, so there is only one section. It's not a section generated with the "derived part" menu. Also i took care to "store view" the first scene then to "restore view" the others scences to be sure that it was going to capture the same images...
Old   July 11, 2011, 17:42
Okay, I'm sorry. How did you get that grid? I think, it's not the grid, the scene moved relative to the grid.
Old   July 12, 2011, 10:18
djan
You can add a grid via the annotation menu, but first you will have to setup the grid by going to tools-->annotation-->add anotation-->grid
Hope this helps
HELP! time step too small? meangreen Main CFD Forum 6 May 31, 2018 10:41
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 12:32
