February 20, 2011, 07:38 |
Drag coefficient not even close
I am a mechanical engineering student on mye 2nd year and therefore have no prerequisites on doing CFD (taking first fluid course now). However I participate in Formula student, and we hope to use CCM+ a lot.
I started doing the tutorial on this site: http://www.computationalfluids.com/library.htm (flow around circular cylinder) The problem is I can not get the right value for the drag coefficient. As seen in the picture below, the value -0,0866... is way to low, as it should have been 0,4 and separation at 120degrees. Is this the right way to measure the drag coefficient? The mesh is 13566 cells (the largest one in the tutorial) Re: 15,7x10^6 water at 10m/s cylinder D=1,4m |
February 23, 2011, 16:17 |
You don't need segregated fluid temperature and I think you need a better mesh to get close to the experimentally obtained value. Try trimmer mesh with prism layers.
March 4, 2011, 04:24 |
But is the drag coefficient actually that far away?
I have read that Cd is dependant on Re, turbulence, wake and that the high Cd of 0,4 do belong to the laminar regime. At this setup, water is entering at 10m/s. Maybe 0,0866 is not that far away? |
drag coefficient, newbie, tutorial |
Drag Coefficient Convergence Problem | John | FLUENT | 18 | June 24, 2023 09:22 |
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 00:49 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
Drag coefficient for parcels in dieselFoam | sebastian_vogl | OpenFOAM Running, Solving & CFD | 5 | December 31, 2008 12:19 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
