Problem with heat flux and Symmetry Plane
Old   March 4, 2011, 05:01
Default Problem with heat flux and Symmetry Plane
Tom Schmitz
Zuixy is on a distinguished road
Hey,
I'm modelling a sensor for a heat transfer experiment but i have 2 problems.
1: The sensor is simplified a cylinder. Due to the symmetry i just want to simulate one half. If i do so and set the symmetry plane as a Symmetry Plane I'll get the temperature maximum not in the center like expected but a bit displace. I use a 3D Model. Do i have to use an axisymmetric model? And if so how do i set the axis?
2: To get the radial heat flux which is getting in the sensor I used a cylinder section from the derived parts, the Area Averaged Report and the field function Boundary Heat Flux. But i just get 0 and that's wrong.
Thanks for your help.
Zuixy
Zuixy is offline   Reply With Quote
cylinder, heat flux
directMappedPatch for LES syoon OpenFOAM Running, Solving & CFD 7 November 14, 2010 11:03
Difference between sum(Wall Heat Flow)@Wall1 and areaInt(Wall Heat Flux)@Wall1 danr CFX 1 October 11, 2009 17:37
Heat flux BC in axisymmetric case kevin FLUENT 0 February 7, 2008 18:07
2-D conjugate heat transfer Barbaros CFX 7 August 12, 2006 01:45
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
