P4 cpu vs i7 extreme
Old   April 30, 2011, 14:41
Default P4 cpu vs i7 extreme
Mehrdad
mbn1454 is on a distinguished road
I am trying to compare P4 cpu and I7 CPU. My desktop computer is a Quadcore with I7 CPU (24 gig ram) and I have access to a supercomputer with thousands of P4 cores. My initial comparison shows that my desktop computer is equivalent to about 80 P4 cpus. Does this look right? Has there been such significant improvement in hardware technology since the time P4 introduced?
mbn1454 is offline   Reply With Quote
Old   May 1, 2011, 06:55
abdul099 is on a distinguished road
There was a massive improvement in hardware technology. For example, a Xeon X5550 (2,67GHz, Nehalem architecture which is the same as an i7) is about twice as fast as a Xeon E??? (3,0GHz, Core 2architecture).
But you should not forget some other effects. When running in parallel, the communication time between processes has a big impact on the efficiency. Any additional CPU will increase the communication effort and at a certain point, it will take LONGER when using MORE CPU's. As a rule of thumb, it doen't make much sense to run a case with less than 100 000 cells per CPU, although this might vary slightly with the latency for communication.
To check how much faster your i7 is, run a case on a single core of your i7 and on a single P4 and compare the times for some iterations.
abdul099 is offline   Reply With Quote
stop when I run in parallel Nolwenn OpenFOAM 36 March 21, 2021 04:56
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
OpenFOAM 13 Intel quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 13 February 5, 2008 05:26
OpenFOAM 13 AMD quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 1 November 10, 2007 23:23
Dual Core CPU hjasak OpenFOAM Running, Solving & CFD 5 July 22, 2006 03:57
