Aerodynamic simulation
Old   April 28, 2011, 08:28
Default Aerodynamic simulation
Michele
Maicol is on a distinguished road
Hi everybody,
I have to make an aerodynamic simulation, how can I build a control volume (such as a wind tunnel)after importing the geometry I have to simulate?
then, once I have made this system (body + wind tunnel) which is the best way to operate: give solid properties to body and fluid to control volume, or make a boolean operation to subtract body from control volume and give fluid properties to the resulting volume?
thank you!
Maicol is offline   Reply With Quote
Old   April 28, 2011, 08:39
Ryne Whitehill
rwryne is on a distinguished road
Originally Posted by Maicol View Post
Hi everybody,
thank you!
Import the geometry as a part, create a box part to the size you want, then do a boolean subtract with the box part as the "target part"
rwryne is offline   Reply With Quote
Old   April 28, 2011, 10:32
Michele
very kind of you, many thanks
Old   April 29, 2011, 05:30
Michele
I tried the way you suggested, I subtracted a sphere from a tunnel (in STAR DESIGN), it works correctly.
I tried onother way, too: import two separate bodies in STAR CCM, but i have a problem to asign properties to singular bodies (such as physical properties, mesh sizing etc..): when I am importing geometries, which is the best way to import: create a new region or a new part?
Have you ever made something similar?
I really thank everyone of you is interested in giving me an answer
Old   April 29, 2011, 09:52
Ryne Whitehill
I prefer to import as a part. You then need to create an empty region with boundaries and assign the surfaces of the part to the region boundaries. Then do Mesh->Initialize Meshing, which transfers the geometric data from the Part level to the Region level.
It is a good habit to import as a part as I have heard that eventually CD-Adapco is going to do away with the import as region.
Old   April 30, 2011, 11:03
Michele
Thank you Ryne!
Old   May 1, 2011, 07:32
abdul099 is on a distinguished road
When you've imported a part, you can right-click on it and choose either "set region" (older versions) or "assign parts to regions" (newer versions). That helps much saving time as you don't have to create a region and boundaries by hand and assing surfaces to boundaries.
abdul099 is offline   Reply With Quote
Old   May 2, 2011, 06:25
Michele
Thanks for your suggestion Abdul...I tried this way too I have to define 2 mesh and 2 physic cases to define properties for 2 parts, isn't it?
Old   May 2, 2011, 08:17
Ryne Whitehill
Yes, thank you for correcting me, this is how I typically do it. Much easier than doing it by hand.
Old   May 3, 2011, 03:34
No. As long as they share the same physics, you need only one physics continuum. But you shouldn't have two ISOLATED parts, there should be some connection like interfaces between them.
And for the mesh continuum, you usually use only one as well as long as you don't want to give completely different values or models to different regions.
Will you have two regions? When doing so, is it necessary to have two regions?
Old   May 3, 2011, 07:58
Michele
in case of a air flow on a solid body i should have a physics continuum for solid part and a physics continuum to define gas properties..am i saying a right thing?
Old   May 3, 2011, 08:30
Ryne Whitehill
If you are only interseted in the air flow, then you do not need a continuum for the solid part. You will only need the 2nd continuum if you are intersted in something like the heat transfer through the solid.
Old   May 3, 2011, 09:48
Michele
Ok..however I have to mesh both the "solid" region and the fluid region, isn't it?
Old   May 3, 2011, 10:51
Ryne Whitehill
Think about it in terms of volume mesh, not surface mesh. You only need a volume mesh where your interests lie. If you are just interested in the aerodynamic solution, you only need a volume mesh in the flow field.
The volume mesh of the flow field will use the surface boundaries of the solid body.
Old   May 5, 2011, 02:21
Michele
thank you Ryne, I will check the simulation using one volume mesh
Aerodynamic simulation Amech1423 Fidelity CFD 1 June 5, 2011 06:13
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 08:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 18:57
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
