Mesh Morphing Field Function
Old   August 9, 2011, 10:55
Default Mesh Morphing Field Function
Florian
dirty_harry is on a distinguished road
Hi @ all,
I am trying to simulate a bullet through an barell with Mesh Morphing and Translation. What I need is a Field Function who says the the bullet is moving every 0.00001seconds, 0.01meters, any Ideas????
thanks for your help.
dirty_harry is offline   Reply With Quote
Old   August 9, 2011, 13:28
abdul099 is on a distinguished road
Why don't use the displacement option for the morpher? Otherwise calculate the velocity and use velocity as morphing option. Should be the easiest way, especially when the velocity (and therefore the displacement) is constant.
When it shouldn't be constant (for example due to the acceleration of the bullet due to the pressure), my first thought would be to use 6DOF morphing or try to find an equation for the velocity. Something like v = a*t
abdul099 is offline   Reply With Quote
Old   August 11, 2011, 08:04
Florian
Thanks for the advice....but how does it works when i reaches the max. streching of the cells to remesh it. Means not stop the simulation and remesh it, kinda automatition?
Thanks
Old   August 11, 2011, 10:07
Ping
ping is on a distinguished road
this sort of work is done with a simple java macro - have an outside loop which loops forever, then within the loop use some test to trigger a remesh - eg when mesh is 50% larger than last remesh, or a cell quality report. You then get the value of displacement from a report (or your F=ma calc in the macro), transform/scale etc the 3D CAD or Part solid or surface, then remesh and continue the loop - the region surfaces will be updated before remeshing begins. Like all macros, you record the steps first then insert the loop and get.value reports etc.
ping is offline   Reply With Quote
Old   August 11, 2011, 12:14
Florian
ok, thank you very much,
I never did something with Macro. So, I will try to work it out, hopefully.
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
Mesh for 3 dim Geometry Phil FLUENT 9 July 12, 2000 04:39
