Fully developed flow inlet
Old   November 22, 2011, 11:29
Default Fully developed flow inlet
Imran
Pleb is on a distinguished road
Hi, I am having major problems creating a fully developed flow inlet condition.
I am modelling a straight pipe using LES. I am trying to use the outlet boundary from this sim as the inlet for another sim. I have attempted to use tables but no luck as i need the inlet to vary with time (turbulent flow). The exported table with time will not import directly to the inlet as the table is set out incorrectly!
Ideally i need a sythetic fully turbulent inlet condition like fluent but this doesnt seem to exist in Star!
Any ideas welcome
Thanks!
Pleb is offline   Reply With Quote
Old   November 22, 2011, 12:57
kyle is on a distinguished road
Are you trying to run these two simulations at the same time or using one to generate the boundary conditions for the other?
Either way, this can be done with tables. You just need to use a macro to update the tables that is run every timestep.
If you are running both simulations at the same time, there is also the Co-simulation feature. I have not used it.
kyle is offline   Reply With Quote
Old   November 23, 2011, 15:54
abdul099 is on a distinguished road
I would do a co-simulation approach. Have a look to the user guide, search for "Data Mapper".
abdul099 is offline   Reply With Quote
Old   November 24, 2011, 10:56
Imran
Oooo okay thanks for the replies.
The co simulation sounds interesting but no, i want to use the results from the straight pipe for the resonator sim.
Hmmm i have not used a macro before. So I should set up a macro to export and import an xyz table each time step? Does that mean i need to run the straight pipe for at least the amount of time i want to run the resonator sim for? Can I instead have tables for, say 500 timesteps and run them on a loop to create a rough synthetic turb flow?
Thanks!
Old   November 24, 2011, 11:57
This is not going to be all that simple. You are likely going to need to write two macros. The first macro would have to run the pipe simulation and export a table each timestep. The second macro would run the second simulation and read in the corresponding table for each timestep.
You may be able to keep the number of files and disk space down by exporting a portion of the solution to a single .CCM file instead of thousands of tables. This would require using data mappers instead of tables. I have only used this to map steady state surface temperatures so I don't know how well it would work.
Old   November 25, 2011, 11:25
Imran
Thanks for you're help Kyle, much appreciated.
Looks like fun times are in store for me! :/
Surely there is more straight forward way for this. I can import a table (time) for the inlet. I just need to be able to export a table with xyz time with the correct format :s
I may still look into co simulation. Any other ideas welcome!
Thanks
Triangular mesh - fully developed flow between parallel plate Amir_Ghasemi Main CFD Forum 3 November 28, 2010 04:52
translational periodic BC vs Fully Developed Profile at Inlet Prakash.Paudel FLUENT 1 August 20, 2010 11:01
initial condition for fully developed flow kmgraju CFX 3 August 6, 2010 05:57
Fully developed flow ,CEL expression kmgraju CFX 0 August 6, 2010 04:15
BC for fully developed turbulent flow in a pipe mmd014 FLUENT 2 May 22, 2009 06:50
