Load previous solution
Old   March 20, 2012, 11:39
Default Load previous solution
Ryan Coe
ryancoe is on a distinguished road
Does anyone know of a way to load a previously computed solution onto a mesh?
I'd like to use a macro to run simulations with a range of parameters, but have each simulation initialized by the same steady solution.
Thanks,
Ryan
Ryan
ryancoe is offline   Reply With Quote
Old   March 20, 2012, 11:52
Ryne Whitehill
rwryne is on a distinguished road
Try doing
1) File->Export and exporting your selected values to a CCM file
2) reimport them via File->Import Volume Mesh.
3) set up a data mapper (Tools->Data Mappers) to transfer the data between regions.
4) Set up a field function to set the initial conditions to the mapped values (i.e. set the Initial Temperature to equal Mapped Temperature)
rwryne is offline   Reply With Quote
Old   March 20, 2012, 11:56
Ryne Whitehill
Also, if you have the new version (7.02) you might try looking at Solution Histories. I have not yet had a chance to play with it or read about them, but it might be able to accomodate what you are wanting to do
Old   September 17, 2012, 21:07
bryan he is on a distinguished road
Originally Posted by rwryne View Post
Try doing
Hi Rwryne,
I followed your steps, and it actually worked. But the problem is, it can work only once.
I mean, after I appiled the field function as initial condition and ran the case for some steps, I cleared the solution(due to other problems), and tried to remap again. However, an error "the field function is not built on the region" came out.
Do you know what's wrong?
Thanks!
bryan he is offline   Reply With Quote
Old   September 20, 2012, 17:53
abdul099 is on a distinguished road
You can use a table when the mesh size is not too large. It works pretty fine, but can need a large amount of memory when the table is too large.
As far as I know, solution history is not yet able to provide initialization values.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   March 7, 2021, 08:58
Default Load Previous Solution
Sam Hill
SamHill is on a distinguished road
I used your method of exporting a ccm file and importing the volume mesh to a new sim file. Can you advise on what kind of data mapper to use to map between regions? I am not getting the solution data I want to map come up in the scalar or vector field functions dialog box.
Any help on this will be greatly appreciated.
Kind regards,
Sam Hill
SamHill is offline   Reply With Quote
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
interFoam solution tolerances mgdenno OpenFOAM 4 September 13, 2011 12:58
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
Transient, initial variables from a previous solution nakor FloEFD, FloWorks & FloTHERM 0 April 22, 2011 04:34
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
