July 31, 2009, 06:13 |
user defined turbulence model
Mika Nuutinen
Rep Power: 16 |
Hi! I'm trying to implement a user defined turbulence model in star-cd 3.26 through subroutines vistur.f and sorkep.f, but it seems that the dissipation equation can't be activated when turbulent viscosity is user defined (vistur.f). Does anyone know a way around this (a switch maybe)?
Another thing: one can't modify the source terms in the wall adjacent cells through sorkep.f at least when standard k-eps model is used. Is this possible if turbulent viscosity is user defined (vistur.f) or does star force the no-good wall functions in that case too ? Regards, Mika Nuutinen |
September 30, 2009, 21:11 |
Sameera Wijeyakulasuriya
Rep Power: 16 |
How do you know that the dissipation equation is not working? I tried a case to incorporate streamline curveture effect into k-epsilon equation but did not get physically realistic results. The flow was accelerating and I couldnot figure out whats going on.
When I tried restricting vistur.f to only where the streamlines curve using cell sets, the code diverges. |
October 1, 2009, 04:08 |
Mika Nuutinen
Rep Power: 16 |
Just by activating sorkep.f and modifying the sources only in the wall adjacent cells (through cell sets) changes nothing because star computes these sources internally based on the wall functions. I learned that Switch 12 allows to use modify k and eps through sorkep.f when vistur.f is activated. Other tricks are still required to modify the wall adjacent source terms....
October 12, 2009, 07:59 |
Anton Lyaskin
Rep Power: 17 |
You can see it in the run summary or at the Equation Status tab in Primary Variables - when you turn on VISTUR subroutine both k and eps will be off. You can turn k back on with SOLVE command but this doesn't work for eps.
Actually I'm facing the similar problem as manuutin - I want to use standard k-eps equations but calculate turbulent viscosity in a non-standard way. I was thinking about defining a passive scalar and treating it as eps (adding the appropriate source term for its transport equation and etc.) but it doesn't look like as reasonable solution... |
October 13, 2009, 11:15 |
Rep Power: 17 |
If I remeber correctly, there is a trick to modify vist via posdat.f. It has been ages since I've used STAR CD so I do not remeber the details properly. But if you make a search on this forum around the period of 2004-5 you might be able to find something. Using posdat you can modify data at different stages of solution, ie what goes into different equations. I think it was something like If (level.eq.1) then... using this you can change your VIST = VIST * correction or however you want to calculate it. This lets you use STAR's in build k-e solver but allowes modification ti VIST. You might have to under-relax a lot in order to avoid divergance at the initial few iterations. Hope this helps.
October 14, 2009, 05:29 |
Anton Lyaskin
Rep Power: 17 |
Thanks, SKK! I'll try the posdat hack.
sorkep.f, user defined, vistur.f |
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 20:21 |
Fan heater model: what turbulence source to use? | andy20 | CFX | 7 | March 3, 2008 16:42 |
validating turbulence model on flow around a car | Pedro | CFX | 1 | February 20, 2008 16:32 |
turbulence model question | Jason Wei | Main CFD Forum | 1 | May 6, 2003 00:45 |
