June 8, 2010, 08:16 |
Problem with Injection
hang zhu
Rep Power: 16 |
Hello everyone,
i'm working on a Spraysimulation in motor. And i've defined some injectors which should inject after 1 deg. But i received a error in the Droplet-post that there is no droplet. And i ve checked the *.spd01 file that it accually didn't inject. The Droplet type and Mass flow Rate have no Prolem, i think. The modell was imported from es-ice. i've no idea where can be the prolem. So, Could someone tell me some possible reasons? Thx in advance Best regards |
June 10, 2010, 05:42 |
hang zhu
Rep Power: 16 |
Hi
i have tried yesterday to inject not diesel which i ve defeined as droplet but water. it injected. but after i changed it to diesel back,it could not inject again. i guess it can be a problem with the droplet properties. but i've checked the panel. there is nothing different with my another model which untill now works good. could anyone else give me some tipps? thx in advance! |
June 14, 2010, 05:11 |
hang zhu
Rep Power: 16 |
hi everyone,
Problem solved. i just deleted the 1. droplet type and defeined new droplet type, on second place, nothing different with the first. at the end it injected. although i didn't understand at all, why it was like this. but at least i can continue my work. it may give you some useful info, if you face the same Problem. best regards hang |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
DPM injection problem | akr | FLUENT | 5 | November 6, 2006 10:34 |
problem in solving "wave generation" problem | san | FLUENT | 2 | April 3, 2006 23:37 |
problem with using colocated code | Jack | Main CFD Forum | 0 | December 15, 2002 00:15 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
