Home > Forums > Software User Forums > Siemens > STAR-CD
About trim polyhedron of Es-ice
Old   September 2, 2011, 23:40
Unhappy About trim polyhedron of Es-ice
zheng jianjun
skylent is on a distinguished road
I use Es-ice/Trimming method to create the moving grid,but I meet this problem when I select "polyhedron" option during trim process.(My version is 4.14) It shows as following:
Store the Port 1 trimmed in database ID 122.
Saved:
trimmed cell data with id 122
Port 1 trimmed
Cells Cell Tbls CP Match CP Tables Splines Splin Tbl Vertices
91869 1 0 0 0 0 737885
ID 697976 1 0 0 0 0 809450
The curtain is not well defined for 7 faces of Port 1.
Failed to find the collapsing layers for Port 1.
The curtain is not well defined for 7 faces of Port 4.
Failed to find the collapsing layers for Port 4.
"Trim,Recover" may allow you to fix the problem and continue.
Failed to cut the Template.
However, when I select "cell division" option during trim process, it can finish the process. But the output grid includes several crack cells.
I have tried to modify the 3D template,trimming splines set, and also the trim parameters.Unfortunately, I haven't found the right way to solve it.
If somone has some experiences about how to deal with this problem,please tell me. thx.
skylent is offline   Reply With Quote
Old   November 7, 2011, 02:24
zheng jianjun
It maybe because of the gemometry file problem, and when I change the distance between the valves and the valve seat from 0.05 to 0.1, the trimming process can finish the work.
ice melting simulation pratikmehta ANSYS 3 April 17, 2013 09:52
Ice Accretion using Fluent Virk FLUENT 2 December 22, 2012 04:14
Ice melting Simulation pratikmehta CFX 13 February 29, 2012 21:14
Right tool for ice flow? mankoff OpenFOAM 2 November 7, 2010 03:40
two phase flow + ice phase and breaking soeren87 OpenFOAM Running, Solving & CFD 0 September 19, 2010 10:20
