February 9, 2012, 11:48 |
multi-component droplets
Rep Power: 14 |
While defining a multi-component droplet (2 components), I am selecting these component from the database, where I have previously did defined their respective properties (molecular weight for instance) However, when running the computation, an error message (number 756) appears, asking to define the molecular weight of the first of my droplet component (which is water). It is requested to use the extended data LIQUIDMW. I am not finding info about that LIQUIDMW in the user-books nor on the forum, and I am wondering why star does not find the molecular weight defined into the database. Does anybody has some tip about this problem and about what I have not done in the right way? Thank you in advance for you advices. /crevoise |
droplet, molecular weight, multi-component, star |
Momentum source coefficient, cylindrical coordinates, circumferential component? | polakse | CFX | 15 | January 18, 2016 02:40 |
Multi Component Flow Modeling | bmatsuo | ANSYS | 0 | June 23, 2011 20:13 |
Add total mass using sources to multi component fluids | mullenc525 | CFX | 1 | February 5, 2011 04:56 |
multi component | ranap | Main CFD Forum | 1 | October 8, 2008 03:00 |
multi component diffusivity | mahut | FLUENT | 0 | October 10, 2007 04:05 |
