Home > Forums > General Forums > Structural Mechanics
Ansys Mechanical 14.0, Axi-symmetric condition in Ansys Mechanical?
Old   October 27, 2013, 09:26
Default Ansys Mechanical 14.0, Axi-symmetric condition in Ansys Mechanical?
SteveFinnan
SteveFinnan is on a distinguished road
How to apply pressure on the inner surface of the wall of cylinder, in such a way that every point on the inner surface will have the uniform pressure?
As you can see from the diagram, I have two different geometry, the stent and balloon. The balloon is the cylindrical shape object, which is inserted into the stent. I want to create a simulation, in which I apply the load on the inner surface of the balloon, then the balloon will expand, which in turn expand the stent.
Please help me. Thanks
SteveFinnan is offline   Reply With Quote
Old   April 8, 2014, 15:33
Smile
Mudassir
Mudassir is on a distinguished road
Just apply Pressure on the inner wall and select it to be Normal to surface.
STEPS:
1-Select 'Static Structural" in outline
2- Apply Loads> Pressure
3- Select inner wall and Apply pressure this to it.
4-In Details of Pressure select "Define By = Normal To"
You are done!
Mudassir is offline   Reply With Quote
Can't restart 2-way FSI using ANSYS 14.0 Workbench MSHowes ANSYS 2 July 3, 2014 13:30
Delta Functions within Ansys Mechanical Stephen Waite Structural Mechanics 2 July 29, 2013 08:56
Results are different for Ansys Fluent 14.0 and Fluent 6.3 syavash Fluent UDF and Scheme Programming 1 February 17, 2013 01:09
Axi - symmetric flow in OpenFOAM ivanddd OpenFOAM Running, Solving & CFD 0 April 2, 2012 05:06
doubts about axi symmetric moving reference frame and eers Main CFD Forum 0 July 9, 2009 15:53
