Home > Forums > General Forums > Structural Mechanics
ANSYS Worbench Symmetry spur gears
Old   August 27, 2014, 16:28
Default ANSYS Worbench Symmetry spur gears
Thony
verdesca2 is on a distinguished road
Hi, I'm trying to make an analysis on spurs gears, and to make the computational cost lower I'm trying to make a cyclic symmetry, but I have an error every time I make the mesh...
I try to make the symmetry with only one gear and it works, so I don't know if its possible to make the symmetry simulation as I wanted.
So, the question is: Is it possible? How?
verdesca2 is offline   Reply With Quote
Old   September 1, 2014, 23:00
Default Spur Gear Cyclic Symmetry
Raj
desservecfd is on a distinguished road
I can think of the problem WB is having while solving for two spur gears. I believe, you are applying cyclic symmetry according to one CS. When it considers second gear, the second one is also applied with the same cyclic symmetry which is representation of wrong physics as it may consider interfering gears. Let me know your objective so that I can guide you. In past, I have worked for such project but we did 1/8th symmetry model and then you can expand it. Probably Ansys APDL would be a better in terms of handling the symmetry option.
Regards,
Rajendra
Desserve Engineering
www.desservees.com
cfd@desservees.com
fea@desservees.com
Rajendra Kachhadia
Desserve Engineering Solutions
cfd@desservees.com
desservecfd is offline   Reply With Quote
Old   September 2, 2014, 10:47
Thony
I'm trying to estimate the stress on the root and tip of the gears for static and cyclic operation. In order to reduce the computational time I was trying to make that cut of the gears and use the symmetry option.
[Other] ANSYS symmetry Problem verdesca2 ANSYS Meshing & Geometry 0 August 26, 2014 10:56
Ansys Structural- Symmetry BC Problem Mudassir Structural Mechanics 3 April 23, 2014 05:35
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
New Cutcells method Ansys 13 symmetry problem and doubt William D Acosta ANSYS 1 June 8, 2011 10:33
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 14:26
