Home > Forums > General Forums > Structural Mechanics
ValueError: invalid literal for int() with base 10 while using Aster inside Salome
Old   December 17, 2014, 04:36
Default ValueError: invalid literal for int() with base 10 while using Aster inside Salome
Zach
ZachJa is on a distinguished road
made a couple days ago linear elastic analysis (simple round bar fixed at sides and loaded at centre) using Aster in Salome-Meca 2014.2 and all was fine ie analysis run OK, results were generated (.rmed file) and I could watch them via ParaViS also inside Salome.
Today tried to repeat the same simulation from zero but when I pressed "run" in Aster I got the following massage in terminal:
File "/home/zach/salome/V2014_2/tools/Code_aster_frontend_20142/lib/python2.7/site-packages/asrun/profil.py", line 480, in parse
'ul' : int(spl[4]),
ValueError: invalid literal for int() with base 10: 'D'
I opened profil.py file and there is the following expression in line 480:
'ul' : int(spl[4]),
Tried to replace int with float (as found on forums), add float after int - but it still does not work.
Have no idea why this error appeared...
Please help to solve it!
ZachJa is offline   Reply With Quote
aster, int() with base 10, invalid literal, salome
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
