Home > Forums > General Forums > Structural Mechanics
Simulate the pressure in Static Structural
Old   March 18, 2016, 04:02
Default Simulate the pressure in Static Structural
Ali
ali_sharifi990 is on a distinguished road
Hi all, I want to simulate pressure of fluid on the flat plate For effect of pressure on the Deformation, the flow passes through to flat plate, Direction y - Axis that is parallel with plate (Crossing flow in plate heat exchanger).
Now, i setup pressure of fluid in the ansys /Component Y P=500Kpa, Is the correct setting to simulate the fluid pressure in the y-direction?
ali_sharifi990 is offline   Reply With Quote
pressure structural
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
Hydrostatic pressure - static structural stokesy Main CFD Forum 0 March 10, 2015 07:24
Overshooting static pressure guns_down FLUENT 0 March 18, 2014 01:19
Static pressure problem Kiat110616 CFX 0 April 12, 2011 13:11
How to simulate a static pressure sensor ? axel cole Fidelity CFD 1 August 22, 2008 20:01
