Home > Forums > General Forums > Structural Mechanics
Ansys Mechanical large deflection convergence problem
Old   March 4, 2024, 04:50
Default Ansys Mechanical large deflection convergence problem
Marcin
destroy is on a distinguished road
Hi everyone,
I am solving a quite simple problem of pipe undergoing pressurizing up to about 10 kPa. Static structural. The model is solved succesfully even with 1 substep when large deflection=off:
However, setting large deflection=on, cause non-convergence, with a standard warning "The solver engine was unable to converge on a solution for the nonlinear problem as constrained". I tried auto time stepping with many substeps on the level of 1000 without success.
Below I listet what I tried:
- changing mesh number of elements through thickness, as 1, 2, 3 or 4 - no effect on convergence,
- changing mesh density through the pipe length, as the higher gradients are in the endings regions - no effect,
- changing the pressure boundary condition, as if it linearly increases from the endings to the final value (depicted below) - didnt help
- trying to use tetrahedral mesh instead, with Nonlinear Adaptive Region option activated - without success,
- activating Semi-implicit option - I just putted command "SEMIIMPLICIT" i.e. without editing this utility' options. This allowed me to solve greater part of the load, however with the extreme deformations which were growing rapidly within the last solved steps, as depicted below on the true-scale deformation field and the charts:
- tuning settings of the Analysis settings ->nonlinear controls -> stabilization; to my suprise this got completely no effect, no matter what option of stabilization I choose or what values of constants I put, I can even completely turn off stabilization and have the same substeps number solved, as for stabilization=program controlled (or some option manually chosen)
I am aware, that in such problems the issue might be simply, the relation between the Young modulus and loads. In my model, I got very small pipe (diameters about 0.3 milimeters), Young modulus about 21 kPa and inside pressure 10 kPa. I can succesfully solve the large-deflection model for decreased pressure to max 2.5 kPa, or with pressure unchanged (10 kPa) but increased Young modulus, up to 100 kPa, if I remember correctly.
Hovever, in my opinion I got correct model, geometry and material properties, which I concluded based on three things: 1) large deflection=off model results, 2) analytical model results, 3) experimental results. All three results are similar. Therefore I still think, that this is the issue of stabilizing the solver, which I am trying to do.
Please guide me, what I might also try to solve the issue,
Kind regards
destroy is offline   Reply With Quote
ANSYS Mechanical - change convergence criteria KeganLeckness Structural Mechanics 2 May 12, 2022 05:57
Ansys Mechanical ADPL large model processing ansystem ANSYS 0 June 26, 2018 05:34
A CFX-POST error (ver 14.5.7) wangyflp88 CFX 2 July 22, 2017 00:17
ANSYS Mechanical problem prince_mech Structural Mechanics 2 April 12, 2017 02:18
Ansys mechanical APDL problem. russogianluca90 ANSYS 0 October 13, 2014 07:38
