Home > Forums > General Forums > Structural Mechanics
"The fluid-solid interface is not valid..."
Old   March 12, 2017, 19:27
Default "The fluid-solid interface is not valid..."
rjw
Richard
rjw is on a distinguished road
Attempting to set-up a FSI, and in the transient structural analysis, I get the following message:
"The fluid solid interface load is not valid for multi-step analysis."
I have selected all faces that will participate in the analysis, but I still get this declaration. Is there a trouble-shooting guide to eliminate this kind of error?My model is not overly complex.
rjw is offline   Reply With Quote
Old   August 5, 2023, 13:43
Post Similar issue: Help!
anish
anishthapa is on a distinguished road
Dear sir,
I am facing similar issue. "The fluid solid interface load is not valid for multi-step analysis."
I was wondering if you had found the solution to defining Fluid Solid Interface in multi-step FSI.
Any suggestion would be appreciated.
Thank you.
anishthapa is offline   Reply With Quote
Old   August 15, 2023, 04:28
河南
Fanxian is on a distinguished road
Dear sir,
I am also facing the same issue, have you solved this problem?
Fanxian is offline   Reply With Quote
Old   March 7, 2024, 04:27
Farkin is on a distinguished road
In this case, I try to make sure that the mesh settings are compatible with multi-step FSI. I look for mismatches between the fluid and solid meshes, especially in the interfaces.
Farkin is offline   Reply With Quote
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 19:42
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 05:36
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
