Home > Forums > General Forums > Structural Mechanics
How to tensile test multiple surface bodies?
Old   May 21, 2015, 12:48
Default How to tensile test multiple surface bodies?
sal
sghod17 is on a distinguished road
I am trying to perform a simulation of a uniaxial tensile test with a group of surface bodies (with a small thickness applied) that is connected to solids to apply the boundary conditions. There is a symmetry condition applied across the cross section of the body. I keep getting the error " A large negative pivot value ( -1.62459881E-07 ) has been encountered in the global assembled matrix. This may be caused by a bad temperature-dependent material property used in the model." Therefore, I changed my materials to structural steel for troubleshooting purposes but the problem continued. I am out of ideas what to do next. Please help!
sghod17 is offline   Reply With Quote
Old   December 24, 2017, 11:43
Pawan
pawangajare22 is on a distinguished road
Me too having the same problem
pawangajare22 is offline   Reply With Quote
large pivot value
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
Surface Tension Test Cases sega OpenFOAM Running, Solving & CFD 2 March 8, 2011 12:19
Test Case for Multiple Reference Model (MRF) CFDtoy Main CFD Forum 0 May 9, 2007 11:45
