May 21, 2015, 12:48 |
How to tensile test multiple surface bodies?
sal
Rep Power: 11 |
I am trying to perform a simulation of a uniaxial tensile test with a group of surface bodies (with a small thickness applied) that is connected to solids to apply the boundary conditions. There is a symmetry condition applied across the cross section of the body. I keep getting the error " A large negative pivot value ( -1.62459881E-07 ) has been encountered in the global assembled matrix. This may be caused by a bad temperature-dependent material property used in the model." Therefore, I changed my materials to structural steel for troubleshooting purposes but the problem continued. I am out of ideas what to do next. Please help!
December 24, 2017, 11:43 |
Pawan
Rep Power: 10 |
Me too having the same problem
large pivot value |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
Surface Tension Test Cases | sega | OpenFOAM Running, Solving & CFD | 2 | March 8, 2011 12:19 |
Test Case for Multiple Reference Model (MRF) | CFDtoy | Main CFD Forum | 0 | May 9, 2007 11:45 |
