Home > Forums > General Forums > Structural Mechanics
prebended bracket, what type of analyssis to perform?
Old   August 29, 2018, 02:57
Default prebended bracket, what type of analyssis to perform?
M. C.
student666 is on a distinguished road
Hi all,
The object in the attached image represents a fixing bracket, used to fix the products to a wooden pallet, during road transport.
I have to study a new type of steel bracket and what I would like to achieve is a folded bracket which, once fixed, it bends and prearranges a downward preload on the adjustable feet, ensuring that these are kept fixed on the wooden pallet.
The question is: I believe that a linear static analysis is not the correct type of analysis, what kind of analysis should I conduct?
student666 is offline   Reply With Quote
Old   August 29, 2018, 04:33
Mrt23 is on a distinguished road
hello.
first step-static nonlinear analysis bracket will be preloaded
second step-transient nonlinear analysis (road loads)
if i understand you correct you have contact interaction, preload bolt and dynamic road loads.
Mrt23 is offline   Reply With Quote
Old   August 29, 2018, 22:51
Christophe is on a distinguished road
If I understand this correctly, I would make the edge of the “not fixed” side have a “compression only support” or just set the vertical displacement on that edge to zero but allow freedom in the other two directions.
Then I would put a fixed displacement on the other edges and the area where the bolt heads touch equal to the uncompressed height difference between the free side and the bolted down side.
Christophe is offline   Reply With Quote
Old   August 30, 2018, 22:05
M. C.
thank you both; I think I should perform a static non linear analysis only.
I would set the same "sliding" BC on both edges that come in contact with the wood: no vertical displacement.
If I understand you properly, you suggest to study the problem when it is in the "not fixed" configuration.
Then you would put a fixed displacement, but I can't properly understad where and how you would set it.
I'm thinking to set this BC on the corner of the "bended edges", could it be right?
I could also use a symmetric model and put a symmetric BC on the longitudinal axis,
Should it be a proper definition for this case, even if it keeps a degree of freedom?(sliding)
I also think that non linearity should comes for the material, as for this loading state the load (displacement) keeps the same direction, isn't it?
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[Other] simulation of closing the gate using moving mesh simin_ds OpenFOAM Meshing & Mesh Conversion 8 April 12, 2019 05:49
interFoam/kOmegaSST tank filling with printStackError/Mules simpomann OpenFOAM Running, Solving & CFD 3 February 17, 2014 17:06
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 14:16
