Plot Contact Tool Results Using Path for multiple load steps |
April 1, 2020, 06:19 |
Ahmed Mirghani
Rep Power: 9 |
Hi Ansys Comunity
Am trying to plot a graph of contact tool results vs path points for multiple load steps (10 Load Steps >>>10 Graphs) using the following command. however I managed to get the same graph but repeated 10 times. what's wrong with the command??. What will be the difference in the command if I want to do the following. 1. Plot the results for different Load-steps. 2. Plot the results for different Sub-steps. Command !!!Here I have a number of commands to define the path...etc. set,first *do,Loop,1,10 /PBC,PATH,,1 /REPLOT PLPATH,FS PLPATH,SD plnsol,cont,SFRIC plnsol,cont,SLIDE *if,Loop,lt,10,then set,next *endif *enddo |
apdl command, contact tool, czm, frictional stress, plot path |
wall shear stress .. PLOT OVER LINE - my results | vitorspadetoventurin | OpenFOAM Post-Processing | 1 | December 6, 2014 16:24 |
Creating a tool to interpolate results | Luis Batista | OpenFOAM Running, Solving & CFD | 2 | April 11, 2013 08:15 |
xy plot help -- large variation in results | alemenchaca | Main CFD Forum | 0 | May 17, 2009 13:45 |
CFDesign v9.0 won't load results | Joe Shifrin | Autodesk Simulation CFD | 5 | July 31, 2008 11:49 |
CFX load Results file | furkan | CFX | 2 | August 24, 2006 07:18 |
