Home > Forums > General Forums > Structural Mechanics
Structural prestress analysis on a rotating wheel fixed at center with rpm as load co
Old   September 24, 2020, 09:50
Default Structural prestress analysis on a rotating wheel fixed at center with rpm as load co
SaiPrasad Chowdavaram's Avatar
SaiPrasad
SaiPrasad Chowdavaram is on a distinguished road
Hi all,
I am performing a prestress analysis on a rotating wheel which is fixed at center having given rom as load condition. I performed the same problem using 2d shell elements and 3d-solid elements separately with all the analysis details same materials, contacts . I observed high frequencies in 3d solid elements case.
Q. Is my observation is correct?
Q. If my observation is correct, what could be the reason for the high frequencies in Solid elements case compared to 2d shell
Q. How can we correlate both the results. Is there any defined explaination behind this.
Please let me know the reason . I thank all for the support. Expecting an explaination for the defined problem.
Thanku all
SaiPrasad Chowdavaram is offline   Reply With Quote
Old   September 25, 2020, 07:06
karachun's Avatar
karachun is on a distinguished road
This depends on many factors. Can you be more specific and show geometry, mesh, mesh order, BC. There are 1000 possibilities to make some errors.
karachun is offline   Reply With Quote
Old   September 25, 2020, 10:03
SaiPrasad
Thanku for the reply but I cannot show u the geometry or mesh or related becoz it is my office problem being confidential . Hope u understand . I am really sorry
Old   September 25, 2020, 15:14
karachun's Avatar
Sorry, no info - no help.
In general if structure can be considered as thin walled and if it meshed, loaded and constrained in the right way then result modes will be almost the same. But "right way" is too complex to write it on a forum. There are many possibilities to make something wrong.
Therefore the answer to your first question is no, your observation isn`t correct. Modes should be similar.
Old   September 26, 2020, 04:56
SaiPrasad
I agree to ur point . Mode shapes are same . I observed that frequency numbers are high . Difference in frequency numbers between the shell and solid mesh is 2Hz
Old   September 26, 2020, 10:23
karachun's Avatar
What is the relative difference? What is frequency order: 10 Hz, 100Hz, 1000 Hz?
Old   September 27, 2020, 11:39
SaiPrasad
First frequency in shell is around 14.5 Hz whereas in solid mesh it is around 16.5 Hz
Old   September 28, 2020, 02:42
karachun's Avatar
~15% relative error. It is not small but also not giant.
I can recommend to perform mesh convergence study - reduce alement size and recalculate model until mode frequencies and shapes stop changing.
Car external aerodynamic with wheel spinning issue hokhay FloEFD, FloWorks & FloTHERM 2 August 18, 2016 04:23
Cfd to ansys thermal to ansys structural interface ssixr ANSYS 17 July 31, 2015 15:18
Tall building structural thermal analysis hyperandey ANSYS 0 August 16, 2010 17:51
stress analysis of a rotating beam(wind blade) Cheyannne ANSYS 0 October 19, 2009 17:06
FSI on a Rotating Structural Model drgolf CFX 9 August 30, 2007 12:08
