October 13, 2021, 03:01 |
Damping in Ansys
SaiPrasad
Rep Power: 8 |
Hi all ...
I have a doubt . I am working as FEA engineer working on Vibration problems . While performing Transient vibrational analysis there is an input that need to be provided in analysis settings of Ansys which is Damping . May I know 1. what is the percentage of damping that is to be used . 2. Is there any hard and fast rule to have specified damping percentage like 2% 3% ... If yes how to justify that.. how to calculate it theoretically . Please help me in sorting out this doubt . Thanks all in advance . Thanks & Regards Saiprasadchowdavaram |
October 13, 2021, 11:11 |
Rep Power: 11 |
Damping is a complex physical phenomenon. It depends both on material properties and more on the type of joints used in structure. For example riveted structures have more damping than welded.
There are no simple and universal methods to calculate damping. Usually damping is determined by experiment. There is a general rule of thumb to use 2-3%, without any theoretical grounding. Try to check some codes for your structure. For example codes for seismic calculations of Nuclear power plants contain damping values for typical nuclear plant components like piping and engineers can use these damping values for their calculations. |
October 14, 2021, 02:06 |
#3 | |
SaiPrasad
Rep Power: 8 |
Please share more info if u have any . |
October 14, 2021, 06:06 |
Rep Power: 11 |
I mentioned enough information.
Selection of adequate damping is up to you. |
ANSYS licenses | gsamsa | ANSYS | 12 | November 20, 2023 14:55 |
FSI simulation in ansys cfx | Arash67.m | CFX | 1 | September 29, 2017 09:52 |
ANSYS ACT ACoustics and Diffuse sound (TRansmission loss) | Many | ANSYS | 0 | February 19, 2016 07:08 |
Fluid structure interaction | jnattia | Main CFD Forum | 25 | May 21, 2015 09:16 |
Ansys workbench problem | Jonny6001 | ANSYS | 2 | September 30, 2010 12:59 |
