Home > Forums > General Forums > Structural Mechanics
LS-DYNA: End-of-file Error using *USER_LOADING_SET
Prev Previous Post   Next Post Next
Old   November 12, 2021, 06:24
Default LS-DYNA: End-of-file Error using *USER_LOADING_SET
Erik Scheurer
erisch is on a distinguished road
I'm new to ls-dyna and simulation as a whole and am getting an error where I don't understand whats wrong.
In my dummy simulation I'm only doing a themal analysis of a simple cube and I'm trying to apply a user load through the keyword: *USER_LOADING_SET in the .k input file:
*USER_LOADING
       1.0       0.0       0.0       0.0       0.0       0.0       0.0       0.0
*USER_LOADING_SET
         1TEMPTN             1         0       0.0       0.0       0.0         0
A simulation with these Parameters result in a Error message:
*** Error 20680 (STR+680)
unexpected end-of-file
This is only the case when USER_LOADING_SET is used and not for only USER_LOADING but I need both.
I know I need to modify the code in dyn21.f of the ls-dyna code and I did but it doesn't reach the function loadsetud where I put my code.
It seems to me that there is a keyword missing that is not named in the manual?
If I use the option FORCEN instead of TEMPTN and do a stress analysis, it calls the load function as expected.
The keyword check in LS-PrePost has no errors and these are the control keywords for the TEMPTN case:
*CONTROL_SOLUTION
         1         0         0       100         0         1
*CONTROL_TERMINATION
       1.0         0       0.0       0.01.000000E8         0
*CONTROL_THERMAL_SOLVER
         1         0        111.00000E-4         8       1.0       1.0       0.0
         0       5001.0000E-101.00000E-4       1.0                           1.0
         0       0.0         0
*CONTROL_THERMAL_TIMESTEP
         1       0.5      0.011.00000E-4       0.1       1.0       0.5         0
Is there a additional keyword that I need to place for USER_LOADING_SET to work? Do you need additional information?
The cube is attatched in a zip.
Thank you for taking a look!
File Type: zip cube_userload_temp.zip (972 Bytes, 3 views)
erisch is offline   Reply With Quote
heat transfer, ls-dyna, thermal analysis, user-defined function
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
