March 12, 2017, 19:27 |
"The fluid-solid interface is not valid..."
Richard
Rep Power: 9 |
Attempting to set-up a FSI, and in the transient structural analysis, I get the following message:
"The fluid solid interface load is not valid for multi-step analysis." I have selected all faces that will participate in the analysis, but I still get this declaration. Is there a trouble-shooting guide to eliminate this kind of error?My model is not overly complex. |
August 5, 2023, 13:43 |
Similar issue: Help!
anish
Dear sir,
I am facing similar issue. "The fluid solid interface load is not valid for multi-step analysis." I was wondering if you had found the solution to defining Fluid Solid Interface in multi-step FSI. Any suggestion would be appreciated. Thank you. |
August 15, 2023, 04:28 |
河南
Dear sir,
I am also facing the same issue, have you solved this problem? |
March 7, 2024, 04:27 |
Rep Power: 2 |
In this case, I try to make sure that the mesh settings are compatible with multi-step FSI. I look for mismatches between the fluid and solid meshes, especially in the interfaces.
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Error in Two phase (condensation) modeling | adilsyyed | CFX | 15 | June 24, 2015 19:42 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Problem Interface Solid Fluid with wall velocity Solver v12 | hills1 | CFX | 2 | October 12, 2009 05:36 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
