Home > Forums > Software User Forums > SU2 > SU2 Installation
SU2 Parallel Computation
Like Tree2Likes
  • 1 Post By rktchip
  • 1 Post By rktchip
Old   June 5, 2013, 09:41
Default SU2 Parallel Computation
Pay D.
pdp.aero is on a distinguished road
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= EXIT CODE: 255
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
Traceback (most recent call last):
File "parallel_computation.py", line 153, in <module>
main()
File "parallel_computation.py", line 53, in main
options.output )
File "parallel_computation.py", line 106, in parallel_computation
libSU2_run.SU2_DDC(Config_DDC_filename,partitions)
File "/home/payam/PDP/MyWork/SU2/SU2CODE/SU2_v2.0.1/SU2_v2.0.1/trunk/SU2Py/libSU2_run.py", line 18, in SU2_DDC
run_command( the_Command )
File "/home/payam/PDP/MyWork/SU2/SU2CODE/SU2_v2.0.1/SU2_v2.0.1/trunk/SU2Py/libSU2_run.py", line 107, in run_command
raise Exception , "SU2 process returned error '%s'" % return_code
Exception: SU2 process returned error '255'
***also when i try the same python command with sudo "sudo python parallel_computation.py -f inv_ONERAM6.cfg -p 4" i will get this message :
File "parallel_computation.py", line 24, in <module>
import os, time, sys, shutil, libSU2, libSU2_run
File "/home/payam/PDP/MyWork/SU2/SU2CODE/SU2_v2.0.1/SU2_v2.0.1/trunk/SU2Py/libSU2_run.py", line 5, in <module>
SU2_RUN = os.environ['SU2_RUN']
File "/usr/local/lib/python2.6/UserDict.py", line 22, in __getitem__
raise KeyError(key)
KeyError: 'SU2_RUN'
pdp.aero is offline   Reply With Quote
Old   June 5, 2013, 11:07
Pay D.
Thank you Developers. I figure out my problem.
Old   June 13, 2013, 02:13
Default hello
何建东
hejiandong is on a distinguished road
= EXIT CODE: 255
main()
options.output )
raise KeyError(key)
KeyError: 'SU2_RUN'
hello! when running parallel_computation.py, i confronted the same problem with u, could u tell me how to solve this problem, thank u!!
hejiandong is offline   Reply With Quote
Old   June 13, 2013, 17:16
Trent Lukaczyk
rktchip is on a distinguished road
Glad you got it working, would be nice to know what you fixed.
Also a comment, you should not need to run sudo to execute SU2
- Trent
pdp.aero likes this.
rktchip is offline   Reply With Quote
Old   June 14, 2013, 10:42
Pay D.
- Trent
Thank you for a comment, yes I know, It is just a habit.
As you know building the SU2_DDC needs metis, So I have two version of metis in my system, metis-5.0.3 installed in my root and metis-4.0.3 in my trunk. When I was trying to build the code with metis-5.0.3, I got that error. I used mpicxx first and then change it to mpicc and then mpirun and nothing has been changed,So that is irrelevant to my compiler, Thus I compiled metis-4 first and then configure the code with metis-4.0.3 header and libs without cgns lib, moreover I used SU2_v2.0.1 instead of SU2_v2 and it is working great now, but still I cannot understand something, why every time that I reboot my system I have to export environment variable for SU2_RUN, Otherwise I got an error about couldn't find SU2_RUN.
I would like to thank you for your great work, It would be a great honor to use your code for my research work.
payam
Old   June 19, 2013, 14:02
Trent Lukaczyk
great, yeah metis 5 operates a bit differently from 4. glad you got it working
you can edit your bashrc file (~/.bashrc) to export SU2_RUN everytime you boot up.
best,
- trent
problem in the CFX12.1 parallel computation BalanceChen ANSYS 2 July 7, 2011 10:26
Parallel computation using NUMECA 6.1 BalanceChen Fidelity CFD 1 June 5, 2011 06:24
load balancing in parallel computation shyamdsundar Main CFD Forum 0 September 2, 2009 23:53
Why the parallel computation is slow ztdep OpenFOAM Running, Solving & CFD 1 May 1, 2008 04:55
how to parallel computation Jane Siemens 2 April 28, 2004 06:11
