January 30, 2016, 01:53 |
SU2v4.0.0 parallel installation error
mohit
Rep Power: 10 |
Hi everyone,
I am trying to install the SU2v4.0.0 using parallel build but got stuck in the first step of configuration. here's the command used for configuration: ./configure --enable-mpi --with-cc=/usr/local/bin/mpicc --with-cxx=/usr/local/bin/mpicxx And i am totally confused about what is wrong with this step (have i missed any prerequisites for parallel build) even when i have installed openmpi as recommended on the SU2 website. But the output of the above configure goes like this: checking build system type... x86_64-unknown-linux-gnu checking host system type... x86_64-unknown-linux-gnu checking target system type... x86_64-unknown-linux-gnu checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether make supports nested variables... yes checking for style of include used by make... GNU checking whether the C++ compiler works... no configure: error: in `/home/mohit/Desktop/softwares/SU2v4.0.0': configure: error: C++ compiler cannot create executables See `config.log' for more details One of the annoying thing about the above message is that i could not understand the reason for why the c++ compiler didn't works. One more thing to mention that when i tried to install SU2v4.1.0 on different system, it works but i don't know what is wrong with the installation of this version. And one more thing not regarding SU2 install but about the forum that whenever i tried to attach a file, it would return with the message of Upload errors : invalid file. I don't understand whether i am violating any of the protocols for attaching some file or is it something else. I would be grateful if anyone could tell me the right way for attaching any file along with the thread to post on the forum. Thanks in advance. |
February 19, 2016, 01:59 |
Francisco Palacios
Rep Power: 15 |
Hi, it could be a permission problem in the target directory...
Anyway, if you google "whether the C++ compiler works... no" it doesn't seem an isolated problem. Good luck! and thanks for using SU2, Best, Francisco Palacios |
February 19, 2016, 13:17 |
#3 | |
mohit
Rep Power: 10 |
First of all, thank you very much for your reply. After I put the post, I later realised that my ubuntu version 14.10 did not had the basic automake or autoconf tools, which seems to be the reason for above mentioned error. Later I upgraded to ubuntu 14.04 LTS with the required tools and get the SU2 installed properly. Secondly, I would like to ask you that the multigrid, being the tool for accelerating the convergence whether I should use it for a transonic flow simulation (M=0.9). Also, is there any way by which I can extract the value of turbulent kinetic energy from the simulation? As turbulent kinetic energy is related to the sound pressure levels in the transonic regime. Any help would be appreciable. |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
