Could SU2 be run in parallel on windows without using Ubuntu BASH? |
May 24, 2019, 06:52 |
Angu Praveen
Rep Power: 6 |
Dear all,
I am trying perform a BWB aircraft optimization using SU2 and SUAVE. I would like the following questions to be answered. 1. Could SU2 be run in parallel on windows 10 without using Ubuntu BASH? 2. Could SU2 be called into Python(Spyder/Anaconda prompt) and run there instead of the command prompt? If so, can someone help me with the process? PS : I have successfully run SU2 using both bash and also windows command prompt in my PC in sequential. And the link in windows is very important as the connecting softwares between SU2 and SUAVE( gmsh and OpenVSP) are installed correctly on a windows operating system and have been successfully imported into Python. Thanks in advance Kind Regards Angu Praveen |
How do I run SU2 in parallel on windows? | Flare | SU2 | 5 | May 31, 2022 09:01 |
[Salome] Salome import "Cannot find file "points" in directory..." | mismichael | OpenFOAM Meshing & Mesh Conversion | 5 | June 22, 2019 02:56 |
MPI error when trying to run su2 in parallel | Gui_AP | SU2 | 11 | June 3, 2019 03:38 |
SU2 parallel run results visualization | ddvdc | SU2 | 1 | February 12, 2019 16:14 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
