Home > Forums > Software User Forums > SU2 > SU2 Installation
SU2 installation error on Linux:about c++ compiler
Like Tree1Likes
  • 1 Post By pbrady2013
Old   July 20, 2019, 07:43
Default SU2 installation error on Linux:about c++ compiler
Yue Zehua
yuezehua is on a distinguished road
Hi there,
whihe installing su2 on my Centos work station, I met this error when doing ./configure and enabling mpi settings. I typed:
./configure --prefix=/opt/software/SU2 CXXFLAGS="-O3" --enable-mpi --with-c=/opt/software/mpi/openmpi/1.6.5/gnu/4.8.2/bin/mpicc --with-cxx=/opt/spftware/mpi/openmpi/1.6.5/gnu/4.8.2/bin/mpicxx
however, there's an error:
checking whether we are cross compiling... configure: error: in `/home/customer/desktop/Yue/SU2/SU2-6.2.0':
configure: error: cannot run C++ compiled programs.
If you meant to cross compile, use `--host'.
See `config.log' for more details
so I checked the 'config.log':
configure:3550: ./conftest
./conftest: error while loading shared libraries: libmpi_cxx.so.1: cannot open shared object file: No such file or directory
configure:3554: $? = 127
configure:3561: error: in `/home/customer/desktop/Yue/SU2/SU2-6.2.0':
configure:3563: error: cannot run C++ compiled programs.
See `config.log' for more details.
but when i do "./configure', it shows c++ compiler is working(as checking whether c++ compiler works ... yes), so I'm really confused why there's a error about the c++ compiler as mentioned above, and i'm a new learner in CFD, waiting for your help! thanks a lot!!
yuezehua is offline   Reply With Quote
Old   July 21, 2019, 22:38
Default Library Search Paths
Peter Brady
pbrady2013 is on a distinguished road
Hi Yuezehua,
When I come across an error like this:
It usually indicates I've messed up my environment. So PATH and LD_LIBRARY_PATH. Can you double check that they are pointing to a location that includes the file: libmpi_cxx.so.1
Beyond that I also use a similar command line to you but also force particular compiler versions - I use custom GCC and MPI that are newer than the default CentOS, here it is:
./configure --prefix=/Users/pbrady/esi/jobs/2018-0004-02    \
   CXXFLAGS=-O3 \
   --enable-mpi \
   --with-cc=/Users/pbrady/devTools/bin/mpicc \
   --with-cxx=/Users/pbrady/devTools/bin/mpic++ \
   CXX=/Users/pbrady/devTools/bin/g++ \
   CC=/Users/pbrady/devTools/bin/gcc \
   CPP=/Users/pbrady/devTools/bin/cpp
Hope that helps,
-pete
yuezehua likes this.
pbrady2013 is offline   Reply With Quote
Old   July 22, 2019, 05:40
Yue Zehua
Originally Posted by pbrady2013 View Post
Hi Yuezehua,
   CXXFLAGS=-O3 \
   --enable-mpi \
Hope that helps,
-pete
i found i chooesed an old gcc file, and after linked it to a new gcc path, it works
thanks for your help!
[OpenFOAM.com] Installing on Ubuntu 18.04 samiam1000 OpenFOAM Installation 11 April 27, 2020 00:01
[OpenFOAM.com] Issue configuring ./makeParaView - Ubuntu 16.04 bjdarrer OpenFOAM Installation 2 April 20, 2020 13:50
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
