January 30, 2023, 07:35 |
FAILED: meson-install
Shreya S Khanapur
Rep Power: 3 |
[804/805] Installing files.
update CoolProp /home/aselab/SU2/subprojects/CoolProp /home/aselab/SU2/build CoolProp updated Installation failed due to insufficient permissions. Attempting to use polkit to gain elevated privileges... Directory /home/aselab/SU2/externals/codi is not empty Maybe submodules are already cloned with git? FAILED: meson-install /home/aselab/anaconda3/bin/python3 /home/aselab/SU2/meson.py install --no-rebuild ninja: build stopped: subcommand failed. Can you please help me out with this? I'm not sure why the installation has failed. I'm trying to install SU2 7.5.0 and this is what happens when I run the ninja command. |
January 31, 2023, 06:01 |
bigfoot
Rep Power: 17 |
It looks like it tries to create,modify or delete a file or folder but it does not have the correct read/write permissions. Are you updating an existing installation?
Maybe you can try to clone the repository again in an empty folder and build it from there. |
January 31, 2023, 08:40 |
fatal error: mpi.h: No such file or directory
Shreya S Khanapur
Rep Power: 3 |
Thank you! But now I'm getting another error although I've installed all the dependencies. Please help me out with this one.
I have attached the URL for the screenshot below: https://drive.google.com/file/d/1JSm...9h-pRvdyT/view |
February 1, 2023, 08:19 |
bigfoot
Rep Power: 17 |
How do you compile your code? What are the exact commands? Does this work:
cd /home/wastre/su2_source/ git clone https://github.com/su2code/SU2.git ./meson.py build --prefix=/home/wastre/su2_source/SU2 ./ninja -C build install |
February 9, 2023, 06:49 |
Shreya S Khanapur
Rep Power: 3 |
I could install SU2 7.4.0 successfully though, using the same commands. I'll just go ahead with that for now. Thanks a lot for your time.
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 15:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
